I have a 2018 320S, and am hoping to fit dual 6V batteries in the tub.
Any tips on how to remove the PVC pipe attached to the inside front of plastic propane tubs? It's held in place by two tap-in brads. I'm worried about cracking the tub and will appreciate ideas on how to do it with no collateral damage.
I tried putting a small hammer inside to tap them out, but there's not enough room to swing with any effect. I tried multiple screwdriver bits, but none grabbed hold in the smooth round depression on the brads. I tried wiggling the tube to loosen the brads, but it didn't budge.
Thanks for any and all suggestions!
2018 320S - 2017 V6 Toyota Highlander - Port Townsend WA
Mine was riveted in, I drilled them out.
2016 Max S, 2011 Volvo XC60
You want to drill JUST the head of the rivet. Once you have drilled far enough to separate the head of the rivet from the shank you can easily pull the shank and the expanded part of it out from the PVC tube side. Aluminum rivets are soft so drill slowly.
Assuming the head of the rivet is actually completely detached from the shank, you could use a small (the diameter of the rivet shank or slightly smaller) punch and gently tap from the outside. The end of the shank is likely pulled into the PVC. Or, have you tried pulling the entire PVC tube away from the tub--rivets and all? Without the heads on the rivets it should pull away with little force.
From outside of Tub, select a drill bit a little larger than rivet center, slight drilling will cause outer 'washer like' part to come off pop-rivet.
Adventures: 55 Nights: 376 Towing Miles 46,920
