I am using the water for the first time in my 400. I have been using the city water for the past day but decided to fill the tank and try the pump. After disconnecting the city and filling the tank, I turned on the pump and water started pouring out of the city water connection. Any idea what the issue is? Is there a valve that is supposed to prevent that?
2023 F-150 Powerboost hybrid
2019 T@B 400 Boondock
0 ·
I believe this is the one on my 320. Note that this connection can be ordered with either a male or female pipe thread fitting for the inside water line connection. I believe mine is a male fitting on the port, female on the inside water line.
https://www.amazon.com/CAMPER-MOTORHOME-TRAILER-MARINE-FLANGE/dp/B017MONLP2/
@klenger has the right idea until you can get the city connection repaired.
Here's my photo of what it looks like inside our 320S..
You can see the male threads at the check valve, which appears to be plastic, vs. the Amazon part which appears to be brass. I hope they made it more accessible in the 400 model, because I can barely get the tip of one finger on it reaching through the hatch behind the toilet. One needs long arms to get to it, and there is no flexible tubing at the end, so you cannot pull the line out from the outside for servicing.
I guess I’m going to need to “see” a check valve to understand better what is involved in replacing it.
Assuming you can get to that water line's connection to the outside port from the inside, then it should just be a matter of unscrewing the knurled female connector sleeve that screws onto it from the inside. Then the port can be replaced from the outside. I'm assuming the check valve is built into the outside city water port assembly.
If that inside connector sleeve is easily accessible from the inside, 400 owners are a lot better off than 320S owners who would need very long arms.
If you look closely at the photos of the fresh water port at klenger's Amazon link, you can see in the middle two photos views from inside & out of what appears to me to be a check valve inside the port which would prevent water flow from inside to outside.
The closet set is approximately 19” from the floor and approximately 26” from the outside door. The hatch entry is about the size of a cargo door (going by memory on this measurement) and even I should be able to reach the outside wall where the water connection is.
To those with 400’s who are looking, caution, the rear of the converter is just below the hatch opening—there’s 110V and 12V there, although the bare ends of the wiring should not be exposed.
This is a screen grab from the Air Force Guy's factory tour video. I'm trying to show two possible routes to getting at where I thought the valve was located below the closet floor level on the outer wall. If you could get into that corner cabinet might be better access.
Great if you can see the line entering from the inside, because that's where the connecting nut would need to be unscrewed to release the line (need to drain & blow out all lines first!) in order to remove the port from the outside for replacement.
