Front window
Warped front window.  Like to replace with upgrade (aluminum frame).  Where to look?
  • jkjenn
    jkjenn Member Posts: 6,421
    You will need to order through a dealer. If you have a DM T@b it might be a little tricky.
  • freebird919
    freebird919 Member Posts: 3
    TY!  Ours is the Outback with shower.  I’m really looking to find a Co. that will replace with something more robust.  Plexi is ok but warping is not!
  • jkjenn
    Good luck and let us know what you find. @Dalehelman has created a slide in cover to protect his.
  • freebird919
    I’ll let y’all know 4 sure and I saw that ingenious cover.  I’ve found that a great UV camper cover is very helpful though (like the one I purchased from Pahaque).
