Front window
freebird919
Member Posts: 3
Warped front window. Like to replace with upgrade (aluminum frame). Where to look?
You will need to order through a dealer. If you have a DM T@b it might be a little tricky.freebird919 said:Warped front window. Like to replace with upgrade (aluminum frame). Where to look?2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
TY! Ours is the Outback with shower. I’m really looking to find a Co. that will replace with something more robust. Plexi is ok but warping is not!
Good luck and let us know what you find. @Dalehelman has created a slide in cover to protect his.
I’ll let y’all know 4 sure and I saw that ingenious cover. I’ve found that a great UV camper cover is very helpful though (like the one I purchased from Pahaque).
- 919 Introductions
- 74 Teardrop Groups & Links
