Good Day All,
I wanted a wired live action rear view camera without drilling any holes in our new 320S. I preferred a wired solution for reliability and to avoid RF interference associated with wireless alternatives. This is still a work in progress but here is what I have completed to date.
The camera is a 170 degree viewing angle color HD camera and the screen is 4.3" LCD HD. Many other options are available but I wanted something small to fit under my dash. I am still undecided where I will tap into the 12v power source for the camera. Probably a simple SPST switch mounted in the front tub directly to the battery or maybe tap into the 7-pin trailer plug junction box. All the components were purchased from Amazon for less than $50. Since I plan to route the AV cable under my Ridgeline I purchased a 10m extension cable. I will probably snake the cable inside the trailer frame or just keep it on the outside along the frame secured with nylon cable clamps. Once everything is mounted I will heat shrink the connections allowing for the simple disconnect of the camera to truck plug.
4.3" screen in cubby space in front of 2017 Ridgeline console shifter.
Huntington LI
0 ·
Cable ran behind plate. Connectors are now heat shrink wrapped.
Camera mounted using existing plate light screw. Plate light doesn't interfere with camera due to offset mounting.
Huntington LI
Screen closed when not in use.
Huntington LI
12v power for screen using lighter plug.
Huntington LI
Yellow is video to screen, red is 12v power for camera. (cable sitting on top of spare tire mounted on trailer jack)
Huntington LI
Huntington LI
Huntington LI
Huntington LI
Used this extension cable from license plate to front tub to access battery power to avoid drilling holes in trailer to access 12v.
Huntington LI
The Swift Hitch is a good device. The Ridgeline has a tailgate 3-way back up camera that covers my hitch. But I was looking to increase my situational awareness, something behind my T@B that would allow me to watch the adjoining lanes of traffic especially when looking to change lanes. Living on LI with the parkways off limits to trailers, my only way off the island requires me to transverse bridges through NYC where the SOBs don't give you a break and seem to enjoy passing trailers and cutting you off. I was not able to find suitable mirror extensions to increase my field of view so the rear view camera became my alternative.
Huntington LI
Yellow connector to TV extension cable terminating at hitch. Red connector disconnects to cut power to camera.
Huntington LI
This cable clamp screw over the hump I installed to eliminate cable slack. Remainder of the clamps utilized existing screws.
Huntington LI
Project ready for road test once the weather breaks.
Huntington LI
https://swifthitch.com/collections/featured-products/products/sh04
Huntington LI
Update on testing. The camera appears to be very accurate. The garbage can on the screen is exactly 12' from the camera lens and 4' off the driver's side of the trailer. The field of view at 12' is 16'+ and at the fence 30' back from the lens the FOV is more than 50'.
Huntington LI
It's good that it's local WiFi, in addition to its internet accessibility. It would be interesting to know how the latency is with a cell connection. I would think it'd be pretty hard to use as a back-up camera with the latency that would come via the internet! But useful as a short term security camera, as long as you have internet access.
Huntington LI
Huntington LI
Thanks for the detailed account of your cable routing.
[1] Connector used.
[2] How much cable slack.
[3] Rain/Snow protection.
[4] How do you store the TV end (at hitch) when not in use.
[5] Any pictures.
Huntington LI
It was on sale at Costco last month for $99. Just screw it on as a license plate frame, and it comes with a separate display and mount that looks like like an iphone. Seems to work fine- but haven't taken a trip with it yet.
