Hello all--just wondering if anyone has replaced their jack wheel with something a bit wider or a different type of rubber that is more like a tire (still only 6" diameter) so that it rolls better? I was not happy with the way the standard wheel rolled on my concrete driveway. The jack wheel I had on my old little popup trailer was easier to get pointed in the right direction than this one. I was expecting this trailer to turn easily as many people here have said it does, and I did not find that to be the case--I had to work to get the wheel going into the 90 degree pivot I was making in my driveway to get it into it's spot. I checked Harbor Freight and they didn't have anything that was 6" diameter with the hole in the short post to run the pin through.
Also--is this a 2" diameter post?
2016 Nissan Frontier SV V6 4x4
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
0 ·
2018 320 S - "No Agenda Hacienda"
Tow Vehicle 2023 Honda Pilot AWD
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Woohoo!
I believe it's the crappy jockey wheel that's the problem. I'm going to have to change it out to something else.
Thanks to everyone for your ideas and thread links!
Woohoo!
Woohoo!
https://www.northerntool.com/shop/tools/product_200660371_200660371
and attached it to this plate:
https://www.amazon.com/dp/B004QEJ6UQ
The ball bearings are very smooth and allow us to easily move the T@b on our driveway. The stock wheel took considerably more force than my weak joints can deliver.
Woohoo!
Ikc001
Read your post about front jack wheels. Last your I went to Farm and Fleet in northern Illinois(southern Wisconsin) and purchased two softer 6in wheels and a long bolt. I put one on each side of the hard plastic wheel. Our camper moves a lot easier, even on grass. The wheels are out there, most farm supply stores will have them. Good luck.
Gary/ 2015 T@b MaxS 2016 Toyota 4-Runner
https://www.amazon.com/Curt-Manufacturing-28272-CURT-Jack/dp/B004QEJ6UQ/ref=mp_s_a_1_3?crid=2Y3WAVUZQ9V7U&keywords=jack+foot+plate&qid=1555116066&s=gateway&sprefix=Jack+foot&sr=8-3
Woohoo!
As @dfsdogs said, the footplate tube fit right into the jack tube, pin and all.
2013 Tundra TRD 5.7L
Massachusetts
