Bump on the roof left side
BarteurBarteur Member Posts: 24
edited April 2019 in Factory Comments
Hi everyone coming back from camping yesterday and had to wash the T@B for the first time and noticed that bump on the roof. Is this normal? Thanks
EDITED FOR PICTURE SIZE
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,012
    Looks like a dent to me.
    It does not look normal. I would get this looked at, right away. A few questions:
    1. Is it still under warranty? If so, reach out to your dealer.
    2. Did you do the solar of did the factory?
    Seeing that solar panel makes me wonder about the heat produced by the dark panel with no ventilation underneath... Seems like it would create an oven out of the Tab in the sun.
    Or at least possibly warp the roof?
  • BarteurBarteur Member Posts: 24
    I bought it used but the dealer gave me a year warranty so until October 2019.
    I was told the solar was factory it came with it but I bought it used...
    I will have it check.
    Thanks!
    Pretty good point!
    Pretty good point!
    To me it looks like someone kneeled on the roof.  May well be an easy fix if the aluminum frame underneath is not involved.
    I have seen dents created by walnuts falling onto the roof.  They resolved all by themselves.  Lesson learned - watch where you park!
    Looking at the picture twice i see where your comment is coming from but the bump is going up not down the picture doesn’t give it justice...
  • grubbstergrubbster Member Posts: 115
    edited April 2019
    What model T@B is this and where on the camper is the bump located.  It looks to be on the port side to the rear.  What structure is under the bump?  Any interior walls?  Some structure below could be pushing up.
    2023 F-150 Powerboost hybrid
    2019 T@B 400 Boondock
  • BirdieJaneBirdieJane Member Posts: 237
    As I look at the photo, my eye follows the black rubber trim. Almost looks like a glancing blow by something fairly large while under tow.
    aka BirdieJane towed by Quinn
    It’s a Tabitha and there’s no structure in that area
    Can you see the bump from the inside?
    No
