Hello all! So my first foray into de-winterizing all by myself going well so far. Question-- I am testing the alde hot water now. I am noticing that when I turn the pump on before I open any faucet to call for water that the pump makes a low humming noise-- it is not pumping water. When the water pump runs it makes a much louder noise. I also noticed that the previous owner had put a small piece of soft rubberized backed material on top of the pump to separate the pump from the pipe just above it. I'm guessing to dampen the pump noise? What is this humming noise? When I turn off the pump all noise stops.
2018 Tab 400
0 ·
Sold 2023 Tab 400
Sold 2018 T@B 320S
@lkc001, How long does the pump run after you turn it on and before you open a faucet? Make sure the pump filter and all connections are tight. It should only run for a short time.
Regarding the Alde heating water: when the Alde is turned on without heating the cabin, the water needs time to warm to a default temperature. The boost only works when you are heating the cabin. Selecting boost, temporarily (30 min.) stops the hot glycol from circulating so cold glycol does not return to the Alde and cool the temperature. Basically, the water benefits by the retained heat from the glycol. So, unless you are heating your cabin, don't expect the boost to add to your hot water.
Hooked up to city water with the pressure reducing valve - the sputtering from the hot water faucets stops in a couple to a few minutes tops.
Filling the Alde from the fresh water tank takes much longer. I am not sure how much volume per minute that the pump moves into the Alde. Sorry, can't be exact here. That's why I always advise to prime the plumbing system at home using a hose before going somewhere that you will depend on your fresh water tank.
