We have a 2018 320S Boondock and after opening it up last month we had issues with the pump which ran, but wouldn't draw from the fresh water tank. I blew out the system in the fall so I tried various suggestions here on the forum for removing air from the system to no avail. Then after pulling water into the pump manually, it still wouldn't move any water so I'm pretty sure I need a new pump. Does anyone have any recommendations for pump and specs. I've seen Shurflo recommended on here, so would appreciate any more confirmation or other suggestions. Thanks!
2018 T@B 320-S Boondock, black trim
2012 Toyota Highlander Limited Hybrid
Dave, Lisa, and Fozzie
Seattle, WA
0 ·
A 2018 model - - - aren't you still under warranty ? If so contact your dealer (Apache ?)
Before replacing the water pump suggest you take it apart. The lower plastic section could have dirt/whatever clogging the passageways or it's built in check valve
As for full replacement I would replace with same brand & model - - - my T@B has the Shurflo and it is a quality pump.
Adventures: 55 Nights: 376 Towing Miles 46,920
I changed out my pump lump on my 2015 T@B 320S with this pump from Amazon. If it comes down to replacing your pump, check out the specs on the pump assembly, try to match them or go 5# greater if you prefer to. Just keep in mind that a stronger pump will drain your freshwater tank quicker. ;-)
Shurflo 2088-554-144 Fresh Water Pump, 12 Volts, 3.5 Gallons Per Minute, 45 Psi https://www.amazon.com/dp/B00C1M6B1C/ref=cm_sw_r_cp_api_i_y9nYCbEA5BF49
Did you try disconnecting the flexible hoses attached to both sides of the pump from their connections to the rigid pipes & put intake hose in a bucket of water & output hose into an empty bucket & test that way?
Seattle, WA
I'm sorry for the frustration and troubles.
