Hello all---testing my systems on propane this weekend & the Alde was making a fair amount of rumbling noise at the start-up of heating water in the hot water tank. I have read numerous threads about the "freight train" effect & I'm going to have to contact my dealer to see if they know if the high altitude kit was put on this trailer for the old owner. On electric it was completely silent on both water heating & cabin heating. Temp on the Alde was set as low as it would go because I did not need heat in the trailer. It seemed like after the hot water tank really started heating water that the rumbling quieted down. I have not tested the heat in the trailer on propane, so it remains to be seen if I get the "freight train" noise. My question actually is, I have seen posts where some people talk about turning a "pressure" valve of some kind down to "2" and if that dial is set too high it can also make the Alde rumble. I know that adjustment is somewhere in the Alde area under the bench seat, but what does it actually look like? I played contortionist this weekend putting the bug fuzz in the window tracks & checking on my Alde fluid and was just done playing yoga. I did not readily see any knob that had numbers on it. Thanks for any help! PS I'm in Denver so 5,000-5,300 something in altitutde and do high altitude camping all summer.
2018 Tab 400
0 ·
The high altitude Alde rumble is actually a combustion problem , so is only on propane.
You might be able to see the extra propane gas regulator that would have been installed as the "high altitude kit". I believe its installed under the Tab, in the area where the gas line penetrates the floor, under the back bench. It looks similar to the regulator that's connected to your propane tank up front. But it does sound as though you don't have it.
Sold 2023 Tab 400
Sold 2018 T@B 320S
