2004 Dutchman
need the bolt pattern for a 2004 tab Dutchman can’t find a wheel for a spare.  Tried to measure, looks like 5 on 4 3/4 is that correct?  Can’t find a wheel that size anywhere.  Need help😶
    I you can take a road wheel to Discount Tire or some other tire dealer they will have gauges with which to get all of the necessary measurements such as wheel size, bolt pattern/diameter, offset/setback, wheel width, hub diameter, and several other dimensions.
  • rfuss928rfuss928 Member Posts: 1,147
    edited May 2019
    5 X 100 - 5 bolts on a 100mm circle.
    15x5.5" steel wheels with 195-60x15 tires (spare)
    or
    16x6" alloy wheels with 205-55x16 tires standard from DM
    These sizes and offsets are common wheels on many VWs and other compact sedans.
    Have fun....
  • MonkieMonkie Member Posts: 5
    Thanks for the information, tried that and everyone said it was a 5 on 5and 1/2.  But they don’t bolt up I think it is 5 o 4 and 3/4, looking for someone to confirm that.  I’ve measured it my self and it looks like 5 on 4and 3/4.  ???😶
    5 X 100 - 5 bolts on a 100mm (~4inch) circle.
