Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Type of suspension
Rerail
Member Posts: 22
Folks,
I would like to know the type of suspension on the T@B 320. I can see that it appears to be a torsion bar type as per my previous trailer. When I purchased the trailer, the sales person did not know. He said it was torsion bar but did know the brand. I am assuming something like a Dexter system
Thanks,
Keith Stamper
Port Colborne,
Ont Canada
Thanks,
Keith Stamper
Port Colborne,
Ont Canada
Yes, Dexter Torflex. ( at least since 2016 )For T@B 320 S two axle pitches are available; standard and 'boondock models' which adds some additional ground clearance.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
But just to make it clear, they are not torsion bars.
see it as a sqiare tube with 4 rubbers piece in each corners, and a smaller metal shaft press tight in the middle. The resistance from the 4 piece of rubber is what is acting as the suspension when there is movement.
will try to find a video.2017 T@G Max Outback "Le Refuge"
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC -
Does the 400 use the same type of suspension?gande
2018 T@b 400
2019 Ram 1500 crew cab / 5.7 V8 -
Luckyj said:A vid explains it way better than I can.Thanks for posting the informative video. I did not know how exactly the system worked.I've never found the T@b 320's suspension particularly compliant, but I don't really have much of a basis for comparison.2016 T@b 320 CS-S - 2018 GMC Sierra - St. Catharines, Ontario, Canada
@gande yes, same type of axle, but might be a higher weight capacity.2019 T@B 400 Boondock Lite
Do not jack or let anyone jack on the axle tube either! could damage it.
2018 T@B 400, 2017 Nissan Titan Crew cab -
And now that I know how the axle works I have a better understanding of why!atlasb said:Do not jack or let anyone jack on the axle tube either! could damage it.
Suspension compliance (ride) is not so much a function of its type, whether leaf, coil, air or torsion, but it's effective travel. The Dexter axle IMHO is a good, simple and robust unit. It is NOT, however, particularly compliant. I'd venture a guess that it's got around 3 useful inches of travel. Suspension is, by nature, a sorry compromise. Any more travel and it's either too tall or dragging hard parts. Any less travel and it's a buckboard.
A pint never holds more
Than a pint...
WilliamA2021 Jeep Cherokee Trailhawk
2017 T@G XL
Can generally be found around west-central Wisconsin. -
We've found the T@b to bounce less since adding the hitch tightener. We run 35 psi in the tires and maybe a few thousand miles have softened it up a bit. It sure seems better than the first year we towed it.2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620 -
db_cooper said:. . . run 35 psi in the tires and maybe a few thousand miles have softened it up a bit.For myself 35 psi is too near the tires max load being equal to 50% of T@B GVW.I'm running 48 psi and feel it's overkill for the T@B and may reduce it a bit. . . but no way would I go to 35 psi . . .
our actual tire sizes not on table - - you get the idea'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
For the general grabber LT's on the outback I'm happy at 35 psi. I've run 70 mph for 3 hours in 80 degree temps, and the tires were barely above ambient. I figure bouncing tires at 50 psi creates a different stress on the tires and trailer, I did it the first couple trips and thought towing was miserable.
The key is monitoring and paying attention. I won't leave the driveway a pound below 35. I also check tires and hubs at every stop.2015 Max S Outback | 2010 Xterra -- Retired
Thanks to all who responded. I was pretty sure that the suspension was the Dexter type or Torflex. I had this exact same syuspension on the Airstream and it works really well. Yes, never jack the trailer up on the suspension. That will damage the torque arm.
I appreciate the feedback.
Keith Stamper
Port Colborne,
Ont, Canada -
The videos appear to be a reliable source of information. How can people view them since they are marked "private"? Thanks.
- 916 Introductions
- 72 Teardrop Groups & Links
https://www.youtube.com/watch?v=wAXxlQamdyM
