I have a new to me 2017 320 S. The previous owner did not use the hot water. Now at campground when I turn the hot water nozzle on in the shower it smells awful. Is there anything I can do here in the campground to get rid of the smell so I can use the hot water? I haven’t turned the Alde on to heat the water.
2017 320-S
1 ·
I wonder if the previous owner never emptied the Alde tank? Even though they said they never used the hot water doesn’t mean the tank never filled. The Alde tank does not get hot enough to kill the cooties that may be in the tank, I think the tank needs to be cleaned. You need to contact Alde.
Now If it were me, at a campground with full hook ups, I would disconnect from city water, add a 1/4 cup of diluted bleach to your fresh water tank and fill it up with fresh water, run the pump and open all your taps to get bleach throughout the plumbing, then turn off the taps and pump and let the water sit for several hours. I know technically you should not expose the Alde to bleach, but chances are a single exposure should not matter. Check your pump filter to see if there is any debris and check periodically as you run the pump. Then, empty and fill the fresh tank with water and flush the system until there is no further odor of bleach.
Just some more possibilities!
