Question about covering spare tire on front tongue
linolino Member Posts: 232
I’m wondering what others have done to try and cover the exposed part of the tire not covered by a tire cover when it is moved to the front tongue? That’s sloppy sentence 😂
Covers seems to be made to face tow vehicle or lay flat
  • linolino Member Posts: 232
    edited May 2019
    I have many of those
    Thanks
  • MarcelineMarceline Member Posts: 1,659
    The cover that I have wraps pretty far around to the backside. There’s really hardly any rubber exposed.
  • Tabmann400Tabmann400 Member Posts: 22
    edited May 2019
    To: lino
    Answer to your question about the exposed part of the tire after using your cover:   I used a Plaskolite White Corrugated Plastic Sheet from Lowes, item no. 345710; model 1TW3036C. It costs about $11.00. It is wide enough to cut the circular cover.    I sanded it lightly then spray-painted it black.  I first used a cardboard to cut the hole to fit through the tire holder.  Once you fitted the practice cardboard, you can trace your pattern onto the corrugated plastic.
    Manny & Anne, from northeast Florida,  2018 Tab 400,  Silver with black trim, towed by 2017 Ram 1500
    edited May 2019
    The idea of installing the spare tire came from another forum member.  Thanks to him for sharing it.  He has detailed instructions and pictures.  I just added the black plastic cover in front.
    To: lino
    Thanks for the info
