How 'bout some canned beverages? Probably want to let them settle a bit once you get to camp, though...ChanW said:...
A whole lotta canned goods? (I hate canned food)
Yeah we definitely need a simpler bedding system. It just might be the key. The cozy mattress pad/tucked-in-sheet routine should go. It's too much hassle, especially after a long day of driving, and a couple of glasses of wine...Verna said:As long as it fits through cargo door, it may find a home
ScottG said:We mostly leave the bed up as well, but use light sleeping bags--less comfortable, but easy to toss aside for access to storage or conversion to benches.
Mouseketab said:Love my Cargo doors! I do it a bit differently.... I put my water hoses in the passenger cargo door and my electric cord(s) in the driver cargo door.
I don't have an alde or a furnace in mine, so plenty of storage room in that back driver section. The door on the driver side is smaller, but still plenty big to stuff the power cord in there. The door on the passenger side is about the size of an outdoor shower.ChanW said:Carol, you were able to fit a cargo door on the driver's side? Cool, jealous.
On the LG Tab, the Alde takes up a lot of space on the driver's side. I don't know if it would be worth putting one in over there.Mouseketab said:Love my Cargo doors! I do it a bit differently.... I put my water hoses in the passenger cargo door and my electric cord(s) in the driver cargo door.
And don't forget the distance from the load to the bearing (i.e., spare tire to coupling). The good news is I'm pretty sure the orientation of the tire makes no difference--just consider it a point load determined at its center of mass.ChanW said:Verna, I wish it were that simple...
I'd need to calculate the weight based on how far from the axle the spare was/is, further complicated by the fact that it's vertical now, instead of horizontal. I know, I know, just measure from the center of the tire... Maybe. B-)
And then there's the additional mounting hardware.
Am I going overboard with this?!? Heh. You betcha!
TerryV6 said:. . . tongue weight comes to about 310... I was told that this was okay.
The only thing that I had to jettison was our tire mount and spare, which were about 50 pounds. I was hoping to keep this. Oh well,,
The only reason I am posting in this discussion was the idea of adding two of my wife's 20 pound weights to go under the backbench.. Maybe this is okay or would make a difference? Thoughts?
And the Exped Megamat is even more comfortable but it’s not cheap.Ratkity said:I have to 2nd Verna on the 2-3" thermarest vs 3" memory foam for comfort. I still keep my bed in the same place, but only because I'm lazy (it's made up for zombie visits though!).
TerryV6 said:. . . the tongue weight limitation of 10-15 percent of the weight of the trailer. Does the addition of a good TV like my truck add into this for me at all...? ( just trying to find out if the addition of the the tire and mount could still be added because of it.) I am thinking it doesn't it....
