I have been camping for a couple years in my 2018 cs-s, always hooked up to city water. I am now in a camp site with no hookups. I filled the fresh water tank with water and turned on the pump but nothing. I assumed it was user error so I've read everything on this site and everywhere else. I primed and sucked and poured water in tubes. The filter is clean as the day it was bought. I just tried removing the intake tube that is connected to the floor, put it on a cup of water and turned on the pump and nothing. Does that definitely mean my pump is just bad?
Aileen, Muggles & Scout @ 2018 T@b CS-S @ 2018 RAV4 Adventure @ Massachusetts
0 ·
Have you checked the fuse box to see if the 12v pump fuse is bad?
+ Are the cold/hot low point drains closed, might be open from winter
+ Is the Adle relief valve in the closed (handle down) position)
+ Might try, placing Alde in by-pass { close it's cold water feed and
open by-pass } that will reduce the volume of air the pump needs to purge.
Can you place your "cup of water" above the pump intake level so gravity helps it prime?
Adventures: 55 Nights: 376 Towing Miles 46,920
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
So, assuming you tightened all connections at the pump including the filter cup, and you are not getting anything out of the faucet and you are not able to pick up anything on the intake side of the pump. You may well have a bad pump or is there an obstruction in the fresh tank outlet? Recently, someone found large pieces of plastic stuck in the pump intake tubing. Remove that tubing and inspect it. You can also force air up into the fresh tank to try to dislodge something in there.
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado
