jgram2 said:Well @ScottG, if #4 is true, I see a larger hole and prettier cover in your future.
I have a 1935 circa house that has hard copper plumbing. Even so, it needs a pressure regulator. I'd still have great showers. I'm worried that as plumbing ages (including to the house from the street) the diameter of the inside of the pipes decrease due to mineral build-up. It appears much of the house piping has been fully replaced prior to me moving there - I'd say it's about 20 yrs old.4ncar said:😳 yes you do!! I believe that is the max for cpvc piping & fixtures. If you have copper piping and old fashioned plumbing fixtures you may be ok, but....Ratkity said:Not like the >100 psi in my house.
Ratkity said:I have a 1935 circa house that has hard copper plumbing. Even so, it needs a pressure regulator. I'd still have great showers. I'm worried that as plumbing ages (including to the house from the street) the diameter of the inside of the pipes decrease due to mineral build-up. It appears much of the house piping has been fully replaced prior to me moving there - I'd say it's about 20 yrs old.4ncar said:😳 yes you do!! I believe that is the max for cpvc piping & fixtures. If you have copper piping and old fashioned plumbing fixtures you may be ok, but....Ratkity said:Not like the >100 psi in my house.
ChanW said:We had a little lesson, and learned something new, a few years after moving into our 1860s farmhouse. The plumbing was not so old (outhouse as recently as the 1960s), but some was the thin wall flexible copper tubing. Cheaper, I think...
So, combined with the low-ph acidic water, the piping had been eaten away from the inside. Nothing on the outside to indicate, until it began to seep.
We finally found the leak behind the washing machine, after it had rotted the floor!
Before that, I'd thought copper was great. Now I see the point in softener systems, even if hard water is preferred.
I'd bring that pressure down, 'fi were you!Ratkity said:I have a 1935 circa house that has hard copper plumbing. Even so, it needs a pressure regulator. I'd still have great showers. I'm worried that as plumbing ages (including to the house from the street) the diameter of the inside of the pipes decrease due to mineral build-up. It appears much of the house piping has been fully replaced prior to me moving there - I'd say it's about 20 yrs old.4ncar said:😳 yes you do!! I believe that is the max for cpvc piping & fixtures. If you have copper piping and old fashioned plumbing fixtures you may be ok, but....Ratkity said:Not like the >100 psi in my house.
I would be less concerned with calcification restricting pressure then I would be with acidic water thinning the walls and leading to pinhole leaks. My house had all the copper taken out years ago for that very reason. Copper is good only at the fixture end these days... have you had your water tested for ph levels ever? Especially if you are on well water(as I am).Ratkity said:I have a 1935 circa house that has hard copper plumbing. Even so, it needs a pressure regulator. I'd still have great showers. I'm worried that as plumbing ages (including to the house from the street) the diameter of the inside of the pipes decrease due to mineral build-up. It appears much of the house piping has been fully replaced prior to me moving there - I'd say it's about 20 yrs old.4ncar said:😳 yes you do!! I believe that is the max for cpvc piping & fixtures. If you have copper piping and old fashioned plumbing fixtures you may be ok, but....Ratkity said:Not like the >100 psi in my house.
On city water. Haven't had it tested, but it wouldn't be hard to grab a pH test kit or a a pH test meter from a friend from a lab.4ncar said:I would be less concerned with calcification restricting pressure then I would be with acidic water thinning the walls and leading to pinhole leaks. My house had all the copper taken out years ago for that very reason. Copper is good only at the fixture end these days... have you had your water tested for ph levels ever? Especially if you are on well water(as I am).Ratkity said:I have a 1935 circa house that has hard copper plumbing. Even so, it needs a pressure regulator. I'd still have great showers. I'm worried that as plumbing ages (including to the house from the street) the diameter of the inside of the pipes decrease due to mineral build-up. It appears much of the house piping has been fully replaced prior to me moving there - I'd say it's about 20 yrs old.4ncar said:😳 yes you do!! I believe that is the max for cpvc piping & fixtures. If you have copper piping and old fashioned plumbing fixtures you may be ok, but....Ratkity said:Not like the >100 psi in my house.
