Water pump was working fine 2 weeks ago. Now, it is not. Nothing happens when I turn the pump switch on. The owner's manual trouble shooting page says to "Check fuses; Check fittings." I consulted the very helpful "fuses for newbies" Tab guide; however, I still do not know which fuses to check. Please advise. Thank you.
0 ·
Spot on advice! THANK YOU! Once plugged into shore power with the pump turned on, the red 10 amp fuse lit up like a Christmas tree. Installed a new fuse and the pump was back in business. Thank you again Mike for your assistance!
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
