Anti-freeze disposal
This has probably been discussed to death on this forum, but I'll ask anyway: What's a good way of disposing of the liquid you drain from your TAB during dewinterization? Thanks
    @scotty0424 as it’s supposed to be non-toxic you can dump it anywhere.
    I take my old oil and anti-freeze to the local waste facility where they have bulk dump containers.  There is a small charge and they limit the quantity to 4 gallons per visit, but it is a good way to properly dispose.  If you don't have a waste facility close by or one that accepts oil and anti-freeze, check with local mechanics.  They usually have a recycle or dump tank for used fluids.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,871
    As the pink RV antifreeze is nontoxic, it can go into your sanitary system or septic tank at home or via a full hook up at a campsite.  I know it is non-toxic, but I would not dump it into our storm drains as that goes out to our lake.
    I go to a full hookup campground to dewinterize. It all goes down the sewer drain.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • klengerklenger Member Posts: 309
    You wouldn't dump your holding tanks into the storm sewer any time, right?  :)
    Our holding tanks get dumped at a dump station.  Some folks use a bucket as necessary to dump into a house toilet.
    I was at the Grand Canyon a few weeks ago and my gray tank filled with only one night to go.  My site was very difficult to get into and unhook, so instead of heading to the dump station, I used a 10L bucket to dump the gray tank at the CG toilet.  It took 5 trips to empty the gray tank, and much less time than moving to the dump station. I would not recommend this for the black tank though.
