. . . buttons to check the tanks and battery levels are stuck in the depressed position.
Are you sure all buttons arestuck? It would be very odd if that is the case, not a typical failure mode.
Please describe what is occurring; for example. - Battery shut-off is on, T@B on Battery power - Or T@B is on shore power
- Monitor Display reads ? ? ?
- Press Button Name, monitor display reads ? ? ?
T@B's have two different make Tank Monitors installed; SeeLevel and KIB. Which type does your T@B use? In general yr-2019 units have the KIB and older 320 have SeeLevel. I'm not sure what early year 400's have.
'18 320 S, pitched axle, 3020HE; PNW based TV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller Adventures: 57Nights: 399 Towing Miles 49,190
Mutton, without getting into technical talk, it is as simple as the buttons are recessed. This occurred overnight while on shore power.
I was hopeful that this was a known issue with a simple solution. I may end up taking the four screws out to remove the panel. I really don't want to do that if there is another solution.
. . . is as simple as the buttons are recessed. This occurred overnight while on shore power.
. . . may end up taking the four screws out to remove the panel.
Does sound like something inside the panel has slipped or come undone. Believe your idea of removing the screws is the best next step. Should be pretty of wire slack to allow you to inspect how the panel is held together.
As @Sharon_is_SAM said, a 400 most likely has the KIB panel, something like this:
@Bessie Some times those flat rubberlike buttons can get pushed sideways just a little and get caught on the surround. If the depressed buttons seem to be "cocked" a bit to one side you can try using a ballpoint pen to gently push the button in and wiggle it around a bit. If the top of the button is trapped under the surround it will pop black out.
Thanks everyone! We called NuCamp and described the circumstance. We had just picked up the T@B from storage in hot weather and then plugged into shore power with air conditioner on.
Upon taking the panel off and inspecting, the glue holding the area with the buttons onto the panel had come apart. This is what the NuCamp tech expected.
We will try super glue tomorrow and hope that is the fix.
@Bessie Was the explanation that going from hot to cold relatively quickly caused the glue to separate from the plastic panel?
Yes, and I do believe that to be the case. The temp outside has been in the mid-80's. We had the cover on so I imagine the temp inside was in the low 100's. When we brought the T@B home we set the air conditioning at 65. Either the heat or the quick cooling must have affected the glue.
Upon opening the panel, two of the four connect points had separated from the back of the panel. A little superglue and a rubber band took care of it. Removed the rubber band after a few minutes and we are back to normal.
2019 T@B 400. The first photo shows the button above each tank name.
Have a fun and safe weekend.
Glad it was that simple.
Now if I can get the glue off my fingers.
