Renogy Solar Briefcase to Zamp connector
mandt
Renogy makes a Mc4 to sae adaptor cable
https://www.amazon.com/Renogy-MC4-to-SAE-Adaptor/dp/B01N1TALFY/ref=sr_1_4?keywords=MC4+to+SAE+Adapter+12+AWG+Cable&qid=1558658235&s=gateway&sr=8-4
I believe this will work to connect my Renogy panel to the zamp connector as long as I reverse the leads coming from the zamp connector to the battey. I am also ordering a 20 foot extender cable. Am I correct?
Mickey & Terri
2016 Max S
Kalamazoo Michigan
2016 Max S
Kalamazoo Michigan
Correct. Zamp requires a reversed polarity, so just reverse the solar port leads at the battery and use the adapter. Simple fix. Make sure to order 10 gauge extensions to prevent voltage drop.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
SOAPBOX WARNING...Whatever you decide to do, confirm your runs and connections either visually or with a multimeter that tests continuity. That darn Zamp "reverse polarity" thing has generated so much confusion here that I would trust nothing but my own eyes. Just make sure positives are always connected to positives and negatives are always connected to negatives and all will be well!2015 T@B Max S (320)
Zamp didn't do anyone any favors with their financially driven decision. Personally I would remove it and install something else.2009 GMC Canyon, 3.7 liter
2020 320s Boondock lite, With Lots of mods0 -
@mandt, we also removed the Zamp sticker after we reversed the leads at the terminal.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
one advantage of the Zamp plug is that the positive wire is enclosed so its less likely you touch a positive wire to metal and create a spark, short etc. I used the renogy adapter for this reason. When you have the solar panel exposed to the sun its creating juice immediately. If you touch positive to metal and create a short you can damage the battery.4
From advice from others here, we went with the tecmate optimate polarity adapter. It was the easiest for a non electrical techie like me.
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI2
- 144 Events & News
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
