Permanent trim removal
utahusker
Member Posts: 10
Hello,
Has anyone here removed their 320-s trim? If so, does it reveal a clean seam like the CS models?
The reason I ask, is the trim is lifting away from the body in the front. I would love to remove it if it looks nice underneath it. But I don't want to remove it to see, for the fear of causing more damage.
@utahusker, someone posted about this several years ago and included pictures. It can be done, however, I think I remember a caveat about how much excessive time and labor it took to clean up the adhesive. I think the final determination was if it ever had to be done again, the t@b owner wouldn't undertake it, ever. But you can check for yourself using the search feature in the upper right hand area of your screen using a few key words. Good luck.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
You are going g to be left with a lot of unsightly holes. Unless planning to cover with a wrap, it might prove too unattractive.
Thanks, I thought that was the case. It's not that bad I guess😊1
- 417 Service/Maintenance & Recall Notices
