Solar Connection for 400
lpanthers
Member Posts: 32
Me again. I would like to know if the Tab 400 Boondock Lite has the outside solar power connection for portable solar panels?
Thanks,
Lee Schleining
Pisgah Forest, NC
You are going to want to check with a dealer since we are now in model year 2020 production, but last I knew, the answer was, "no."
Agree with Jenn, unless something has changed, no. Anything is possible (within reason) if you want to pay the service department
2019 T@B 400 Boondock Lite -
You know, with the battery inside under the bed, how would you rig up an exterior solar port to plug in a separate charge controller and panels? Would it be easy enough to run it out the side of the 400?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
@Sharon_is_SAM yes, TWD had a port installed through the wall for a portable panel early on. Recently they added the NuCamp roof panel.2019 T@B 400 Boondock Lite
Question to Ham: Is TWD the Delaneys. I might check their YouTube channel.
Thanks.
Lee -
@lpanthers yes, check their channel, pretty sure it was mentioned in one of the early videos of the 400 right after they got it.2019 T@B 400 Boondock Lite
TWD = Travels with Delaney on You Tube. Got it.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
