Outdoor shower pressure....
sugarloafer
Member Posts: 10
...is so low that its unusable. Why isnt the pressure the same as the sink? I've checked for kinked/blocked hose and showerhead and found nothin! Any ideas whats up?
Ours is very low as well.2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
aka BirdieJane towed by Quinn0 -
Some shower heads have a flow adjustment feature. Look the head over closely they usually twist.
- Hash T@B Fun
This has been a chronic problem. Remove the head and see if it makes a difference.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
If you unscrew the shower head and look inside you will see a very very small hole for the water to flow thru. Drill it out larger and water will flow. I did the same thing to the inside shower to get better flow.
2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az2 -
Thanks folks. I will report back!0
We have the same problem with our new 400. Did the drilling out work?
2019 TAB 400 Boondock Lite0 -
Mine had the same issue, had the dealer look at it and the hose was kinked inside the wall. They replaced the hose and it has worked great ever since.0
- 424 Service/Maintenance & Recall Notices
