Outdoor shower pressure....
...is so low that its unusable. Why isnt the pressure the same as the sink? I've checked for kinked/blocked hose and showerhead and found nothin! Any ideas whats up?
  • BirdieJane
    BirdieJane Member Posts: 237
    Ours is very low as well.
    2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
    aka BirdieJane towed by Quinn
  • Dalehelman
    Some shower heads have a flow adjustment feature. Look the head over closely they  usually twist.
    1. Hash  T@B Fun
    This has been a chronic problem.  Remove the head and see if it makes a difference.
  • RollingBnB
    RollingBnB Member Posts: 322
    If you unscrew the shower head and look inside you will see a very very small hole for the water to flow thru. Drill it out larger and water will flow. I did the same thing to the inside shower to get better flow.
    2020 Tiffin Open Road
    2020 Nissan Versa Toad
    Alan & Patty
    Southern Az
  • sugarloafer
    sugarloafer Member Posts: 10
    Thanks folks. I will report back!
  • Sierra
    Sierra Member Posts: 42
    We have the same problem with our new 400. Did the drilling out work?
    2019 TAB 400 Boondock Lite
  • Sparty
    Sparty Member Posts: 9
    Mine had the same issue, had the dealer look at it and the hose was kinked inside the wall.  They replaced the hose and it has worked great ever since.
