This conversion cost less than a buck. Conventional power tongue jacks draw considerable amps from your trailers battery where the drill mod does not. Just something to.consider.
@Dalehelman Are you still making the bolts for this mod available, or are we on our own? I’d love to do it, but no vice or drill press makes it hard to drill a hole correctly in a bolt.
2019 320s BD Lite, white with blue (“Haven”) 2015 Subaru Outback 3.6r (unsafe 200lb tongue weight limit until 2020 models) 2020 Subaru Outback XT Pacific NW
My power jack uses much less than you might expect. Because the tongue weight on a T@B is so light, the current load is 5 amps or less. Given a single operation time of about 1 minute, that works out to about 0.1 AH per operation (less when dropping the tongue because the load is less). The drill still needs to be recharged and that power has to come from somewhere. With my 200 watt solar or if you have campground power, power jack use is not even a concern.
Dale's drill mod for the tongue jack is brilliant. Also, the drill can be used for the stabilizers and BAL leveler. I get a grin on my face every time I use Dale's drill mod. Simple, cheap and highly effective.
We have a Forest River R-Pod 179. After our last trip, I decided that the manual jack had really gotten old. I looked at a lot of different models, and chose this Quick Products electric tongue jack. Installation was relatively easy. I was pleased to see a circuit breaker was included. The only thing lacking for the installation was some wire connectors and a circular terminal for connecting to the battery. Once installed and connected, I tested it, and it worked perfectly. It is both powerful enough and fast. It was just as easy to use and does allow for adjusting for sloping ground.
I should also mention that this electric tongue jack bubble-style leveling cap is another delightful feature for a potential buyer. You see its inclusion makes sure you won’t have any issues ensuring your rig is perfectly level every time you intend on hooking it onto your tow vehicle.
https://tab-rv.vanillacommunity.com/discussion/7149/ucamp-18-power-tongue-jack-conversion-mod
lpanthers
2019 T@B 400 Boondock
Considering a 2023 TaB 400 with the full Lithium option,
2022 Jeep Gladiator High Altitude, Tow Package.
