I have 2017 Tab cs s. Unsure which model Norcold fridge I have.
How much does it draw at startup when it cycles?
I also use a Northern Fridge chest style fridge/freezer. When voltage drops too low it cuts out as a safety feature for the battery.
I suspect this happens when Norcold cuts in, just long enough that the Northern Fridge goes into safety mode.
0 ·
If you are planning to run both frigs on shorepower at a campsite, another idea is to run an extension cord to the 120 outlet on the pedestal. They will both have their own voltage source.
AC:
1.3 amps @ 110 VAC
1.4 amps @ 120 VAC
DC:
11.7 amps @ 12 VDC
13.6 amps @ 14 VDC
Running on Propane:
Ignition relighter: 150 milliamps during ignition, 100 milliamps steady state
Ventilation fan - 240 milliamps when running
Apparently the battery is good as per interstate dealer but it was not tested under load.
Sorry I keep forgetting to check which 2 way Norcold model I have.
Or - I would suggest a larger battery and maybe look into running them off an inverter. But you need a larger battery for starters. Have you tried just the freezer to see if it will stay on by itself?
