Other recent threads about mixing valves and shower heads have me revisiting a mod I've considered for some time.
I don't use my shower very often, but when I do I find it awkward--and wasteful--to have to continually fiddle with adjusting two knobs every time I want to start and stop the flow.
The obvious answer would be to replace the head with a model like the Oxygenics Fury that has a built-in flow control, but I understand that these (possibly by law) do not stop the flow completely.
Other options involve installing my own on-off valve at the shower head, or even swapping out the entire control unit for a more user-friendly one-handed version. (Didn't somebody do this a while back?)
For those who have made or considered such mods, any insight or advice is appreciated.
Just don't tell me to install a mixing valve so I won't need to use the cold tap--I'm much too insecure to have my water mixed for me... :-)
https://www.walmart.com/ip/Dura-Faucet-Single-Lever-RV-Shower-Faucet-Brushed-Satin-Nickel/166876902?wmlspartner=wlpa&selectedSellerId=0&adid=22222222228062808428&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=m&wl3=169608051766&wl4=pla-275201944279&wl5=9033553&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=166876902&wl13=&veh=sem&gclid=CjwKCAjw583nBRBwEiwA7MKvoE1ds5cSeKzlVrtvc3sUFebS98YCGtNSm-r73bGbHKWx_qSv5jtOFRoC8icQAvD_BwE
2022 Ford F350 Tremor | 2022 Cirrus 620
https://www.thefitrv.com/rv-tips/how-to-fix-the-cold-water-blast-in-your-rv-shower/.
And another blog found this to be the best shut off valve which preserved the water temperature, but fully stopped the flow. I would try to put this before the hose.
Just something else to think about.
additional day of gray tank space. Before 3 showers and I needed to dump, afterward installing the Oxygenics Fury it was 4 days. This is on the T@B S Max with 19 gallon gray tank, and T@B 400 with 18 gallon gray water tank.
Are you in the US?
Maybe the Oxygenix is simply more efficient and effective at a lower flow rate, so you don't tend to run it quite as 'wide open'.
All you need is standard residential plumbing skills to connect the Tab 1/2” Pex to the new control valve.
The DuraFaucet single lever looked nice, but it was mostly plastic and leaked at the hose attachment almost immediately. Not loose connection, but from the inside valve part. The hose outlet is oriented on the top of the fixture but reviewers said it could be rotated. They have redesigned it so that you can't flip it around to be on the bottom. If you do, and I did, the lever is on in the down position instead of off. Too easy to bump it on, and bouncing trailer would probably cause it to come on.
I wasn't happy with the Oxygenixs Body Spa shower head either. It was too long and bulky, but worse, the drip when switched off was a pretty big stream. There was no way it was going to save water over the stock head.
So I'm looking for a different lever and will probably try the Oxygenics Fury.
I just used the wand, kept the stock metal hose, on my 400 and the wand screwed on without a leak.
• Others assumed your older T@B's shower head didn't include the shutoff button like theirs (because, you know, you surely would have noticed it by now!), but they didn't want to make you feel bad, so restrained themselves & didn't say anything.
Sorry, but glad you finally found it before you did anything rash, like completely rebuild your shower plumbing a la DH. I did make good use of that button on our last national park trip when I took my first shower in 2 years (in the T@B that is!).
