Learned to fish rainbow trout there with my grandfather in the 60's. Road down to Sentinel is quite the hill... but well worth it.
I hadn’t previously considered the kind of tow vehicle you had. Hybrids ordinarily don’t make good tow vehicles. At least not yet. The electrical systems are designed to devote most of the electrical production to recharging the main battery banks used to propel the vehicle. Toyota’s hybrids have small alternators and small starting batteries because bigger ones generally aren’t needed. You’re problem might be systemic because it simply isn’t designed to charge externally. I’d be reluctant to try to tie into the main generators used to recharge the lithium bank because I’m not sure you’d want to take energy away from that process. I’d recommend talking to someone who is an expert in hybrid systems.GrandmasKid said:Thank all of you for your help. I've traced the current back through the other side of the controller and it is very weak. The junction box is clean without any corrosion and the nuts are tight. The voltage is so weak it barely turns on my circuit tester light. I don't know much about this and have more questions that probably are pretty dumb but here goes. My charge line comes from my TV battery. Is that where it should come from or should it come directly from the alternator? Perhaps my TV (a 2010 Toyota Highlander Hybrid) has an alternator that just can't keep up with the amps that I need to run my Norcold refrigerator in the T@B while driving. I keep thinking maybe I'll buy a multimeter even though it seems a shame to spend the money for something I'll probably use once in my life to tell me something I already suspect. I like my TV for its ride, cargo capacity, and high mpg, so I don't think I'll be trading it in anytime soon. Maybe I should put a flexible solar panel on the roof, or use a battery booster of some sort. Are there any other suggestions for how to handle my problem? Again, thank you very much for your help.
I used to own a Prius. I could be wrong about this, but I don’t think the alternator that recharges the starter battery is the same “generator” that recharges the lithium (NiMH?) bank. As I said previously, I think the charging systems are separate in Toyota’s hybrid systems and the part that charges the starter battery is smaller and less robust. I urge you to talk to a hybrid expert on this.GrandmasKid said:There is something I'm missing. I tow with a Highlander Hybrid. I think its alternator charges the big NiMH batteries and the standard lead acid starter battery. My RV charge line comes off of the starter battery. Since the TV starter battery doesn't seem depleted after a long day of towing, and all the connections in the charge line all the way through to the T@B battery seem fine, it's a mystery to me as to why my T@B is not getting charged while towing.
