Solar Controller mounting in 400
I have a 2018 Tab 400 and am installing a Renogy 200w solar suitcase system.  I need to mount the Renogy Rover 20A controller.  It is 6" w and 8 1/4" h.  The manual is recommending 6" of clearance above and below.
Where are others mounting the controller in their 400s?   Where does NuCamp mount the controller in the 400 when the factory solar is ordered?
Any pictures of your installation will be greatly appreciated.
Thanks for any feedback!
gande
2018 T@b 400
2019 Ram 1500 crew cab / 5.7 V8
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    The factory controller is under the bed, driver side on the front wall of the Alde compartment.
  • grubbster
    grubbster Member Posts: 115
    I mounted mine on the passenger side under the bed to the left of the access door.  It easily allows me to run the cables out.
    2023 F-150 Powerboost hybrid
  • gande
    gande Member Posts: 105
    N7SHG_Ham and @grubbster.
    Could I ask the make and model of the controller you are using?  My Renogy Rover seems quite large for either of these installations, especially if I leave the clearance (for cooling?) the manufacturer recommends.  Maybe I need a smaller controller.
    @grubbster...is yours mounted to the rear of the access door (towards the rear of the trailer)?
    gande
    2018 T@b 400
  • N7SHG_Ham
    @gande it is the Victron that NuCamp is installing at the factory, not sure of size, maybe 4" x 6"?
  • b407driver
    b407driver Member Posts: 139
    2020 T@B400 Boondock Lite w/solar
    2024 T@g 5-wide Black Canyon
  • tteam
    tteam Member Posts: 26
    We have a dealer installe solar panel and Victron MPPT 75-10 controller. We have downloaded the app to monitor the solar output and battery. We have only seen .01 volts from solar and the battery voltage going down. The blue light on the MPPT always blinks. We have it back to the dealer now to see if they can solve the issue. Does anyone have any suggestions?
    Tteam, Wisconsin
    2020 TAB 320S Boondock Lite
    TV: 2018 Jeep Grand Cherokee
  • gande
    I barely know what I'm talking about here but there seems to be a lot of discussion about reversed wiring.  I would talk to the dealer that did the installation after maybe first talking to Victron.
    gande
    2018 T@b 400
    Follow the controller leads and make sure they are connected positive to positive and negative to negative for both the battery and the PV leads.  There have been wires crossed in the past that resulted in malfunction.  The blinking blue light indicates Bulk charging which
  • Jax0913
    Jax0913 Member Posts: 72
    Hey there! We recently installed 200 watt panels and the Rich Solar (basically the Renogy) 20 most controller. I mounted it under the bed on the middle section on the backside facing the rest of the camper. I did mount mine horizontally so I could have ample clearance top and bottom. That allowed my battery leads to be maybe 12”.
    2018 T@B 400
    2020 Toyota Tacoma Double Cab
  • gande
    I ended up returning the Renogy controller and purchasing the Victron 75/15 which is less than half the size of the Renogy.  It easily fit under the bed close to the battery.  I'm using about18" leads to the battery.
    Amazingly, I wired everything correctly and the Renogy 200w suitcase panels easily kept our battery charged on our latest four day trip to Monterey Bay where no hookups were available in the state park.
    gande
    2018 T@b 400
    It is really pretty simple to connect a controller.   I think the hardest part (besides running wire through the trailer) is disconnecting the MC4 connectors!
  • gande
    @Sharon_is_SAM...the MC4 connector tool (about $8 on Amazon) makes disconnecting very easy.
    gande
    2018 T@b 400
    I know, we have...several😏
    pthomas745 Administrator, Moderator Posts: 4,669
    I've never had any luck at all with those "disconnecting" tools.  Broke every one I've ever bought.  Here is a flash: why don't they make them out of metal with some sort of plier action that actually disconnects the MC4?  I wound up filing down the hook points on the connector and using an old pair of needlenose pliers.
  • Cbusguy
    Cbusguy Member Posts: 771
    Just cut off the mc 4 connectors and use appropriately sized Anderson connectors cheaper and no tools required to disconnect.
    2009 GMC Canyon,   3.7 liter
