Replace 2012 TaB Power Center Converter
Jan
Member Posts: 5
The converter of the Parallax 6730D Power Center supplying our 2012 T@B no longer works, so the entire unit needs to be replaced. The model 6730D is no longer available. I like to know what make and model is a good replacement.
Edited for search purposes - Sharon - Moderator
Snoop around here and see if they have a drop in replacement: https://www.progressivedyn.com/rv/2019 T@B 400 Boondock Lite
Here are 2 threads that should be helpful.
https://tab-rv.vanillacommunity.com/discussion/3556/wfco-power-converter
https://tab-rv.vanillacommunity.com/discussion/comment/101806#Comment_101806
Thanks for the comments. I've decided on the Progressive Dynamics 4135KV. Based on the published specs, I will have to alter the cut-out to have it fit, but not by much. Apparently the converter module in this power center can be replaced when it fails, which I hope takes a while.
- 917 Introductions
- 73 Teardrop Groups & Links
