@Cherokee the BD tires have very little fender clearance, that is the install issue. Once over the tire, it works fine. I only ordered mine maybe three months ago and talked to a lady at the "factory" in BC before buying and was assured it would work because I was skeptical due to the tight fit.
I belive after having to take a few back because folks couldn't figure out the trick, Brahma took the safe approach and said they won't work.
I have the factory-installed Rainier Apex tires at 50psi.
As previously alluded to, the 'spec' you are lacking is only marginally included in the 'Boondock Lite' edition options on the webpage, not the standard 400. The BDL shows the tire in the picture, but they do not list the actual tire size on the newly-redesigned website, for some reason.
2020 T@B400 Boondock Lite w/solar 2024 T@g 5-wide Black Canyon TV is 2024 Toyota Land Cruiser LCP Jeff --Front Range of Colorado
