This weekend a section of the rubber trim that joins up to the plastic trim came loose while on the road.  Got out my small stepstool & was going to put on Duct tape to keep it on till I got home-- but was too short to reach top of trailer so I gently pulled it off so I wouldn't lose it & it wouldn't beat up the side of the trailer. I have some shoe goo & see several others have used it.  Do I clean the area with rubbing alcohol first?  Do I just put the glue in the channel in the rubber trim & press it back on or do I need to also put glue on the flat underside of the rubber trim & press onto the trailer roof?  I'm going to go around the entire rubber trim & reattach all of the rubber trim.  Thanks for your ideas & suggestions!
                2018 Tab 400
0 ·
Alan & Patty
Southern Az
I haven't seen any Shoe Goo in awhile. At one point they changed the packaging and called it Amazing Goop. They had different color packages for "Plumber's goop", "Electrician's Goop", "mechanic's Goop", and so forth. It was all the same stuff though--just different marketing. That is when they started adding the nozzle to the package. Lowe's, Home Depot, and probably most hardware stores carry it. Be aware that it doesn't keep well after the end of the tube has been pierced. No matter how I have tried to reseal it, it sets up in the tube within a month or two. If you let the tube lay out on a hot driveway for a couple of hours before you use it the goop will be less viscous and easier to apply.
