Is it normal for the kitchen sink to leak underneath when the gray tank is full? I (luckily) had a bowl stored under the sink, and when I took it out to use it, it was full of water. Last night, our gray tank reached capacity and wouldn't drain the sink until we emptied the tank. Is this leaking a problem for the dealer to check?
0 ·
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
If your black tank isn’t full, you could drain some gray water from the sewer outlet and dump it in the toilet. The black tank is 12 gallons.
