Calling out from battery purgatory here....(my car is now having a battery episode).
Got my new AGM battery on Wednesday and have been plugged into shore power. Turned off shore power last night...and everything that was on is still on this afternoon and the battery is reading 11.5-12. So, until I figure out how to install my battery off switch...should I just leave it? Let it work in the trailer quietly? If I plug into shore power on a more permanent basis, will the AC overide the battery, giving the battery a rest?
sigh. thanks!
p.s. I am finding that a basic knowledge of Trailerology 101 soon requires more focused advanced study...like Batteries 201. (keeps us young)
Once you are happy that it is fully charged, then you can safely store your battery by removing the battery fuse. Leave the fuse out until ready to check or use the battery. Until you learn this new battery’s discharge pattern, I would check the voltage with the fuse in every couple weeks when you are not using the trailer.
If you leave the fuse in and disconnect from shore power, the CO/LP detector as well as other sources of phantom drain will kill your new battery. With an AGM, there is no reason to stay plugged into shore power - that will just cause your converter to run at intervals.
(previous 2018, T@B 320 Outback)
Did you rest the battery after towing or take the reading immediately after towing?
