Has anyone installed the BMV 500 shunt in a 400 under the bed? It seemed like the best place since it’s near the battery but i have concerns about the exposed connections in a storage space. Am I being paranoid or should I find some way to cover it?
                2018 T@B 400, 2015 F150 tow vehicle.
0 ·
That is where I put mine. And I have the same concern. I put my shunt on the forward wall of the storage hitch next to the inverter. It is pretty much out of the way and I don't think anything will shift into it, but...! I intended to call Victron and ask but until I read your post I just forgot.
I'll be interested in any info you acquire.
On another forum I belong to a fellow took a plastic storage container, like cheap tupperware, and cut a couple of holes in it and screwed it over top the shunt to just give it a bit of protection.
Here is what mine looks like now:
I just bought the same cover you have pictured above. I'm trying to figure out what length screws to use. Do you know how thick that wood is where you attached the hard cover?
