As you see, I have a 2008 CS which uses the World Friendship power converter. We're still learning about this camper and seek out the wisdom of this group. When the T@B is hooked up to 30amp power and the 30amp source has issues/flickering, is it reasonable to expect the 12v battery will kick in to ensure power to the devices, like the lights?
I ask because I'm using a device that is sensitive to the power not being consistent and perceive that when the 12v lights are flickering, that the 30a source is having trouble. If that 30a power goes out, shouldn't the 12v lights not flicker as I presume that the 12v battery source is the source?
Am I right in assuming that the 120v power outlets are not supported by the World Friendship when 30a power is cut?
Reading the manual that came with the World Friendship, it has three modes: Absorption (normal), Bulk (charging the 12v battery) and Float (All good and minimal charging). Is the flicker of the 12v lights when the WF is changing modes?
Thanks for reading and helping me understand more.
T@B CS 2008
0 ·
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
(previous 2018, T@B 320 Outback)
I ask because my device, a cell-signal repeater is presently using the 110v power but to isolate issues I want to wire it up into the 12v system so that it should have a consistent power source. I perceive that the lights in the kitchen area are 12v and would use that as a source. The repeater is 12v driven. That's why I'm wondering about the lights flickering and if the campground/offshore power source is an issue.
Later on, I plan to post my findings on using this device for those that want better cell service.
