Does anyone know the purpose of the four plastic "brackets" (for lack of a better description) that are located on the outer edges of the standard Dometic Fan-Tastic Fan exterior vent cover base (two brackets on each side)? Are those intended for mounting an after-market cover over the stock lid? I ordered and plan to install the Camco "Aero-flo" vent cover on my 2019 T@B 320S, so I am curious whether those brackets will work in place of the metal mounting brackets that come with the Aero-flo vent. (Maybe they are designed exclusively for mounting the Fan-Tastic Fan's "Ultra Breeze" cover????) Thanks! (Greg)
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
0 ·
Adventures: 58 Nights: 405 Towing Miles 50,180
Alan & Patty
Southern Az
The plot thickens........... BUT, keep the input coming folks. I love a good mystery. Regardless, I'm sure I will be able to get answers from nüCamp. I am curious if there are other 2019 T@B owners who have the the same plastic brackets on their vent. [I must say, it sometimes seems like nüCamp likes to do stuff like this with little or no fanfare so that T@B owners can "discover" these little improvements on their own.]
I found this video online (scroll to bottom of web page to see it):
https://www.etrailer.com/RV-Vents-and-Fans/Ventline/V3092-601-00.html
It demonstrates how to attach a MaxxAir vent cover to a Ventline base. To attach the new cover, the metal brackets (provided with the after-market cover) are attached to the plastic brackets on the base of the exterior vent mount. Without the plastic brackets, you would have to secure the after-market metal brackets by drilling holes through the metal frame of the trailer vent housing (i.e., the metal frame that the crank-up vent lid rests on when closed.) Thus, the plastic brackets provide a "no drilling required" install. Nice! This is a real bonus for attaching a vent cover on a T@B, because the roof is not designed to support body weight (thus, you are limited to standing on a ladder to complete the install.)
You would have to attach the metal brackets to the plastic ones - not sure there would be clearance for the vertical bolt that the base attaches to. Also, the cover base would have to straddle the plastic brackets - double-check dimensions when the Aeroflo comes in. Your 2019 fan is different than the one on our 2016 320S. See pics:
When I opened the Aeroflo and looked at the instructions I thought, "Only 8 fasteners - gonna knock this out in 20 or 30 minutes." That's what the job would take if you were working from a platform over the T@B. Every step requires ladder moves from side to side. It wound up taking about me about 3 hours.
One other thing to keep in mind:
If the base straddles the plastic and metal brackets and allows the carriage bolts to line up with the base slots you are not necessarily home free. The slots in the Aeroflo base only allow a small amount of front-back adjustment. When opened, the geometry of the fan cover moves the leading edge of the square cover forward - as is shown in your second photo. If the Aeroflo base is mounted too close front edge of the fan cover can hit the base when opened. Without realizing this my instinct was to put the base toward the rear as much as possible to allow the cover to open as much as possible. Unfortunately, the layout of the slots did not allow me to simply slide it forward enough for the necessary cover leading edge clearance. I had to reposition two of the brackets. Having said this, I see your cover has an angled edge instead of being square - so it may not be an issue for you. (But it may be for others which is why I threw it in here.)
Hope it goes smoothly for you.
One other point: the last step in the install is attaching the Aeroflo top to the base. It has slotted hinges in front, rotates rearward onto the base and is held down by two short machine screws in back. The back screws go up through the base into caged nuts that are held in place by the plastic of the top. One went in and tightened up just fine. However, the other one would not get started (I did back off the first one as much as possible for wiggle room). Got it started, but I couldn't get nut tightened - the screw went through the nut, but would not tighten all the way - stripped the nut out of the hex plastic cage. Finally, used a nylon lock nut and a very thin socket to get it tightened. It was not fun working from the ladder, reaching toward the middle of the T@B and fighting stubborn connectors.
Moral - dry fit and tighten those final two screws while you're on the ground before you even start the job - then remove them and begin.
"The new White Vent covers do come with brackets for the purpose of an exterior Vent Cover – such as the Max Air Vent Cover. On other vents without these brackets you have to attach brackets to the factory vent cover in order to attach the Max Air, so this makes it much easier/quicker."
Presumably, it will work with the Aero-flo as well. The installation is similar to the MaxxAir, so it should. I wish Creed would have included info about who manufactures the base with the plastic brackets that nüCamp installed, but I won't bug him about that.
Thank you to those who responded to my inquiry. I will update this thread after I install the Aero-flo on my camper.
Greg
Here I'm speaking from experience. I always try to plan and stay one or two steps ahead of myself when doing these "simple" projects. So once I had the brackets attached to the fan flange, but before putting the nuts on the carriage bolts I tried to put the lid on by sliding the lid hinge bars under the base hinge loop tabs. Huh ... the lid has a little curve that makes it hard to slide the bars under the base loop tabs - no big deal - I'll just leave it attached. Bad idea - works against you when trying to hold the base down and get the carriage bolts into slots that you can't see. I decided to proceed without the lid attached - but knew that after the base was attached I would need help finessing the curved lid hinge bars under the base tab loops.
However, that lid-attached "dry fit" exercise revealed three important things:
1) The leading edge of the fan cover bumps into the front of the Aeroflo top when it is opened, like I mentioned above.
2) The hinge bars on the lid could not slide under the base hinge tabs because they bumped into the flat flange of the fan housing (red arrow below).
And to top it all off:
3) I could not just slide the base forward slightly because I had attached the brackets so the carriage bolts were tight against the cross-piece separating the two short slots (see blue arrow in first photo above).
All the above led to the repositioning of two of the mounting brackets.
All of this will make more sense when you have the Aeroflo in hand.
So - dry fit and tighten those final two screws while you're on the ground before you even start the job - then remove them and begin.
And (now that I'm remembering all these frustrations with the install) I recommend when making sure the two screws go in OK you also make sure the plastic hinge tabs fit correctly. I remember, after struggling a little to get the curved hinge bars on the lid under the base hinge tabs, that I wished I had done a dry fit on the ground. If I had, I would have taken +- 1/8" off a couple of the tabs with an Exacto knife or Dremel to make it fit more easily.
Hope this info helps minimize the time it takes for you or others to do this "simple" job.
SCRATCH THAT. I just pulled the installation manual from a model 1400 Dometic Fan-Tastic vent. The plastic brackets (referred to as "molded pegs") are designed for the Dometic Ultra Breeze hood. https://www.dometic.com/en-us/us/products/climate/ventilation/vents/dometic-fan-tastic-vent-1400-_-186151
I just received the Aero-flo vent that I ordered from Amazon. The metal L-backet is about 2" in length overall, 1 3/4" from the edge to where it bends upward. I am really concerned that the plastic brackets on the Dometic base are going to block the Aero-flo brackets, assuming I will need them to connect the Aero-flo to the Dometic base. I guess I am the first one to encounter this issue. Always nice to be the guinea pig.
Although using a cover specifically designed for use with the Fan-Tastic fan lid would be nice, particularly since it allows for opening the stock vent lid all the way up, I really do not like how the Dometic version looks over-sized on a T@B camper. I suppose having those plastic brackets helps generate revenue for Dometic by forcing people to buy their after-market vent cover, but it sure limits the options for T@B owners. There may be a work-around that will allow me to install the Aero-flo cover without a big hassle, but I won't know until I try to install it. My camper is currently in storage and covered, plus I can't get to the install until sometime next week. Therefore, I'm afraid you will all have to wait until then to see how all this plays out. Thanks again for all the helpful input and moral support. Greg.
You could probably cut off the pins and install the Aero-Flo normally--maybe. The Ultra Breeze is a ponderous, bulky, ugly thing. I'd rather not be stuck with it.
Additionally, the Aero-flo mounting slots are both too small to fit over the plastic brackets and the width of the Aero-flo base is not wide enough to extend far enough to reach the brackets on the opposite side of the Fan-Tastic base. As shown below, although one corner of the Aero-flo can be aligned with one plastic bracket (red arrow), it does not align with the other bracket on the same side (green arrow.) Also, due to the insufficient width of the Aero-flo cover, the opposite side of the base butts up against the stock Fan-Tastic vent lid. I am guessing that Dometic re-designed their base (by adding the plastic brackets) not only to easily attach their after-market cover, but to prevent/deter the attachment of competing covers. However, as I mentioned earlier in this thread, Creed at nüCamp indicated that the plastic brackets will work with a MaxxAir cover. I have not independently confirmed that.
I have returned the Aero-flo cover. However, I am not completely disenchanted with this outcome. Although it would definitely be nice to have the additional cover to keep out the rain while the vent is wide open, my wife and I really did not like the look of the Aero-flo on the roof of my camper. It just seems too bulky and extends too high up on the roof. Were it to be designed to fit the Fan-Tastic brackets, it would have to be wider, which would only exacerbate the bulky look. Since the Fan-Tastic and MaxxAir (standard version) covers are even bulkier and taller, I am not interested in installing either of those. Therefore, I will be sticking with the stock cover, which I think will be fine, even when it rains. (Greg)
Maybe I should use the money saved on the DIY AC Vent cover for a new fan?
Considering the number of "moving parts" (dimension and position-wise) of getting it all to work out I am disappointed, but not surprised, that it wouldn't fit. We also don't really like the bulky aesthetics of the installed aero-flo, but have gotten used to seeing it up there.
2024 T@g 5-wide Black Canyon
I figured I should let others know my experience with installing the Dometic Ultra Breeze Cover over the stock FanTastic vent lid that has plastic mounting brackets. After determining that ONLY an Ultra Breeze cover will work with the plastic mounting brackets (see earlier part of discussion in this thread), I had no choice but to order it. What an ordeal that was! Suffice it to say, despite positive comments by others to the contrary, I give Dometic a D- for customer service based on my experience.
I searched for the cover and thought that the Dometic Ultra Breeze model #U1500 would work, so I ordered it through Amazon. When I received it, I discovered that it did not include the two mounting holes on each side for proper attachment to the mounting brackets. I contacted Dometic. After being on hold for a long period, I was informed that I needed model #U1400. Initially, they were going to sell it to me, I believe for $44.00 + $25.00 shipping. THEN, they told me they could not sell it to me, because it is "finished goods" and I can only get it through one of their local dealers. My wife and I wanted black to match our white w/ black trim 320S camper, so I was advised that I would need #U1400BLS (black smoke.) Searching online, the only retailer I could find that sells the U1400 is eTrailer, but only in gray smoke. I called Dometic back to see if they would sell the black to me. They refused. Despite my multiple requests (by phone and E-mail), they would not allow me to speak to a supervisor. I was hoping they would make an exception and sell it to me without going through a dealer.
I tried a local Dometic dealer (Cactus RV in Tucson, AZ.) To keep a long story short, they would not order it directly from Dometic and said they had to go through their supplier. The dealer had no clue what I was seeking, despite me giving them the specific model number, a photo, a full description, and even the dealer direct phone number for Dometic. They assured me that they would get the right model cover, but it would cost $89.00. However, when I went to pick it up a week later, I was presented with what appeared to be a used model #U1500BLS. They only had the cover itself (scratched up, no installation instructions, no hardware, and no plastic mesh screen.) I let the parts guy know what I thought about their practices and left empty-handed.
Next, I contacted another local Dometic dealer. They too declined to order the vent direct from Dometic. It appeared I was going to get a re-run of my first experience. Sure enough, when I showed up a week later to pick it up, everything was there, but again, it was a scratched up model #U1500BLS. Arghhhh! Sensing my frustration, the dealer agreed to contact Dometic direct. Fast forward another week and I got the correct cover. Poorly packaged by Dometic, so it was scuffed up from bouncing around (without any protective packaging) in an over-sized box. Regardless, I purchased it ($87.00.)
Bottom line is that if you want the Ultra Breeze model #U1400, you can get it in gray smoke (#U1400GRS) through eTrailer.com. However, if you want black smoke (#U1400BLS) or white (#U1400WHS), you must go through a Dometic dealer. BUT, if you want to avoid a three-week hunt like I went through, make sure you convince the dealer to order it directly from Dometic. Otherwise, the dealer will likely just do a quick Google search, find the U1500 model, and order that.
Anyway, I got the cover installed and am very happy with it. Looks great! Installation was quick and easy. Just line up the two mounting holes on each side and insert a 1/4" plastic drive rivet (included) through each of the four holes and into the mounting brackets. Although not depicted in the photos below, you then push the head of the plastic rivet all the way in and the cover snugs up to the plastic mounting pegs. I really like the ease of installation - - no drilling or attaching metal mounting brackets required. The only downside is that it does not appear that you can remove the plastic drive rivets to clean inside or under the cover. The U1500 version has metal brackets with cotter pins that can be pulled out for easy cleaning under the cover, BUT it does not work with a vent that has the plastic mounting brackets.
NOTE: Dometic also manufactures a separate bug screen insert (available on Amazon) that slides in behind and attaches to the included plastic screen that covers the vent opening. As seen in the third photo below, the plastic screen has large openings that will not keep insects out. Therefore, I highly recommend that you purchase the bug screen if you decide to install the Ultra Breeze cover.
I just changed out our pitiful factory fantastic fan in our 2019 320s for a Maxxair .
Here is a picture of the 2019 no screw fan roof when I removed it ..........( was hard to remove !)
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
