MICROWAVE size?
I am not good at math. I see people talking about buying a 700w microwave for size but how much can a 2019 T@B 320 handle when plugged into shore power? Can I have a 900w? We have a U so it will just sit on the counter or little shelf thingy as needed. And yes, I tried to search. And I would love an answer without having to understand the why of it. Thanks friends!😉
  • Tabaz
    Tabaz Member Posts: 2,420
    900 watts divided by 110 volts = 8 amps.  I believe the T@B outlets have a 15 amp fuse, so you should be more than OK.  You could probably get a 1200 watt unit if needed.
  • Cbusguy
    Cbusguy Member Posts: 771
    We have used our microwave while running our AC with no issue on 30 amp service at a campground
    2009 GMC Canyon,   3.7 liter
  • ColleenD2
    ColleenD2 Member Posts: 580
    Thank you!
  • ColleenD2
    @Cbusguy what size microwave?
  • Cbusguy
    It is a .7 cu ft 700 watt
  • Cbusguy
    we were also running the icemaker and occasionally the blender at the same time as well
  • ColleenD2
    Thanks!
