MICROWAVE size?
ColleenD2
Member Posts: 583
I am not good at math. I see people talking about buying a 700w microwave for size but how much can a 2019 T@B 320 handle when plugged into shore power? Can I have a 900w? We have a U so it will just sit on the counter or little shelf thingy as needed. And yes, I tried to search. And I would love an answer without having to understand the why of it. Thanks friends!😉
900 watts divided by 110 volts = 8 amps. I believe the T@B outlets have a 15 amp fuse, so you should be more than OK. You could probably get a 1200 watt unit if needed.2016 Outback 320
We have used our microwave while running our AC with no issue on 30 amp service at a campground2009 GMC Canyon, 3.7 liter
2020 320s Boondock lite, With Lots of mods -
Thank you!2019 Custom T@B 320 U Boondock Lite-ish
We've slept in 34 states, 2 countries & counting -
@Cbusguy what size microwave?2019 Custom T@B 320 U Boondock Lite-ish
It is a .7 cu ft 700 watt2009 GMC Canyon, 3.7 liter
we were also running the icemaker and occasionally the blender at the same time as well2009 GMC Canyon, 3.7 liter
Thanks!2019 Custom T@B 320 U Boondock Lite-ish
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
