Outside door clip
TerryV6
Member Posts: 1,101
My plastic pin on the door and outside clip connector has gotten worn and sloppy and the door won’t stay open. How have others dealt with this? Beef up the pin to make it stick in the clip better, or just replace the part? If replace, original or satisfactory alternative?
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
I am need of repairing mine. A wind gusts at üCamp pulled the catch right out of the wall. From what I u understand, some toothpicks, silicon, and larger screws will create a tighter fit.
I replaced with this and the screw holes lined up.TerryV6 said:My plastic pin on the door and outside clip connector has gotten worn and sloppy and the door won’t stay open. How have others dealt with this? Beef up the pin to make it stick in the clip better, or just replace the part? If replace, original or satisfactory alternative?
AP Products 1/2" 013-084W Plastic Door Holdback-3-1/2, White https://www.amazon.com/dp/B002UC1AUA
@Marceline, thanks for the link. I’ll give that one a try for 6 bucks. Thanks for the input Jenn. I’ll tell you what I think...Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI1 -
We have been using Dale Helman's door strut idea..
https://tab-rv.vanillacommunity.com/discussion/6433/no-more-swinging-door
It keeps the door propped open about 100°, so it fits under our visor, gives more space for the frig vents, can be reached easier from inside for closing and keeps our door-mounted trashcan more accessible when open. Only thing I don't like is that it springs open a little too forcefully, as if caught by a strong wind (probably should have gone with the 15-lb strut instead of 20-lb), so need to hold onto it until it's fully open.-Brian in Chester, Virginia
My 2016 320S only has 2 holes per piece. So, I googled AP Products (from the link provided above-Amazon) and found this one.
https://approducts.net/catalog/index.php?main_page=product_info&cPath=47_50_67&products_id=4043&zenid=6b338ce79a761d0a731f012db109bfd1
I emailed asking for the exact hole measurements.
Heard back from AP with measurements....they matched but they charge $25 to ship a $4 product...
Lisa
Tucson, AZ2016 T@B 320 S Outback ("Scout")TV: 2013 Lexus 450h
"You never know when you're having good luck." ~ Unknown1 -
I also use the strut idea. But, When I don’t have the awning up and just want to swing the door open to load up, it would be nice to have it stay. Looking at the female end of the new part, it appears there is room for a drilled hole for my wire.Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI0 -
Thank you for the link @Marceline I'll take a look at one of those to see if it can be positioned to hold the door open with the visor fitted.0
We got ours today. The holes don't line up and I don’t want to drill a new one. So I am going to add a bit to the peg on the door to make it seat tighter.Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI0 -
Well, I tried to return the hardware and they said okay, here is your money back, keep the part...Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI0 -
Well, to finish this thread for me, I went through a dealer and got a new clip from NuCamp for about $9. Picked it up today. Spring is just over the hill.Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI0 -
Question doesn’t the strut hold the door open?TerryV6 said:I also use the strut idea. But, When I don’t have the awning up and just want to swing the door open to load up, it would be nice to have it stay. Looking at the female end of the new part, it appears there is room for a drilled hole for my wire.
That should be it’s function. Why does the awning up or down make a difference. I must be missing something.- Hash T@B Fun
Yes, my homemade wire strut does work to hold the door in place, but sometimes we want to go in to get something and just swing the door wide so that it goes into the little clippy thing. Very convenient. My wire strut is not attached. I suppose I could do that, but it didn't cost much to put in a new original white clip. The wire strut I made because when you have the awning up, you can't swing the door all thee way. We store it just inside on the left. Should not be too complicated to understand. I, on the other hand, can be...Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI1
