2015 320S - Cold Water Tap Came Off Under Pressure!
Pekoe1111
Member Posts: 54
We turned on the pump switch and the cold water handle blew up to the ceiling, spewing water everywhere inside the bathroom until we turned off the pump. Is there are trick to putting it on so it does not come off, or do I need a new one?
Thanks!
Thanks!
That’s a new one! Are you using a water pressure regulator?
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
Ha! We are not connected to city water - using our onboard water.0
Does there appear to be excess flow pressure from the other faucet? Is this a pump issue or a faucet issue?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Which cold water tap?In ours, the taps on the shower point at the wall. Do you have a sink in the bathroom?The reason I'm specific is that I've some experience with the shower tap handle, it just screws on like any tap handle, but I don't know anything about the sink.Did the valve blow out too, attached to the handle?Got pix?
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
I think the 2015 S models still had sinks in the wet bath.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Nope. At least not mine built in Dec. 2014. Might have been one of the changes implemented mid model year.Sharon_is_SAM said:I think the 2015 S models still had sinks in the wet bath.
The OP said the water went everywhere in the bathroom, so I assume the sink was there.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Hi - yes, this is the cold water handle on the sink. It appears to just push into the faucet, with some rubber o-rings on the valve under the handle. We just bought the camper and were using it for the first time. No way to shut off a valve under the sink either - just a screw-on fitting. So all fittings, including toilet, kitchen sink, etc. are under pressure with pump on. I’ll take a closer look at the fitting to see if there is a turn and lock- type fitting, or how else it make stay attached.
thanks all!0
