Great Trash Can
teztab
Member Posts: 99
Recently found this great little Camco 5 qt trash can, on Amazon. It looks good and functions very well. We have it mounted with adhesive tape on the door of our 320S, so it serves both inside and outside. The flap is spring loaded and the receptacle is easily removed for emptying. Dimensions: 13" high x 8.5" wide x 5" deep. They also offer a smaller, 3 qt version.
https://www.amazon.com/dp/B07SJ86NWD/ref=cm_sw_r_cp_apa_i_StkxDbKWB4XGT
7
Did you mount this with screws or double sided tape?2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0 -
duh, yes I see you did mention that--I was so interested in this trash can. . . . . ! Clever2018 Tab 400
Just make sure the screen is retracted before shutting the door! 😉-Brian in Chester, Virginia
RV: 2018 T@B 320S, >100 mods4 -
I just picked up. Similar sized container from the Cotrainer Store this summer, but I am using it for storage for things like my dog leash and his frisbee....OK, actually, it is Rocky's storage space. The command strips failed. I am going to try VHB adhesive before I resort to using the screws.
Your option is cheaper, though.
2 -
It came with Command Strips and little spots to put the strips on the base plate (the container is magetic) so I thought I would give it a try.teztab said:@jkjenn Looks like a very useful container. I've not had much luck using Command strips for anything other than the Command hooks. 3M heavy duty tape seems to work much better, although more difficult to remove should that time come.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
I have one there, too! Paper plates are kept there for easy access.lkc001 said:@jkjenn I have that same magnetic container on the inside of a kitchen cabinet door— they are great—2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
I've got this one- and love it. It will hang off any of the cabinet doors, or anywhere along the upper side "shelves". I move it around a lot. It's in the kitchen when cooking, and then up and out of the way- maybe next to the AC unit, when not needed.
https://www.amazon.com/gp/product/B07FVNZ6BQ
Silver on Silver, 320S '19 Outback1 -
Hi Teztab, I too am considering that 5Q trash can. How has it help up with the 3M tape? I don't think it's possible to use the mounting screws because of the foam core door on the 320. Was just curious how it is holding up over time! Thanks for any response on this you can give!0
@Coolparrot Yes, the little trash can has been functioning exactly as we had hoped and provides a very space-efficient inside/outside means of handling our garbage. The heavy duty tape has been holding up very well However, if at any time I felt it needed additional support, I would not hesitate to add a couple of screws. Since the outer layers of the Azdel are strong and the inner foam is extremely dense (see close up of section I removed when fitting our bathroom window) I find it takes screws very well. As evidence of this, please see the stainless steel rail with hooks that is pictured here with the trash can. I fitted the rail over two years ago, shortly after getting our 320, and it has not budged. Although it is there for hand and dish towels and the like, it inevitably gets used as a very convenient door pull! One consideration I would suggest is to always use sheet metal screws with a coarse thread that goes all the way to the screw head. That way, the screw will always be biting the skin of the Azdel.Coolparrot said:Hi Teztab, I too am considering that 5Q trash can. How has it help up with the 3M tape? I don't think it's possible to use the mounting screws because of the foam core door on the 320. Was just curious how it is holding up over time! Thanks for any response on this you can give!
@teztab I am not convinced screwing anything to the Azdel, especially the door with constant opening and closing and vibration will hold up. I drilled a hole in mine(not door, BUT same idea) to run a wire, drill went though both layers and that foam like it was hot butter, very little resistance. There is simply very little for a screw to bite into, the foam will hold nothing and you have maybe 2-3 threads on a course threaded screw clinging to that Azdel for dear life.2019 T@B 400 Boondock Lite1
I understand your caution, @N7SHG_Ham, and the probable caution of others, and I certainly do not advocate hanging heavy items with screws. Plus I would always avoid drilling unnecessarily. However, I stand by the experience I explained above: Coarse threaded sheet metal screws, with small pilot holes, will work for many items where tape fails or is not appropriate.N7SHG_Ham said:@teztab I am not convinced screwing anything to the Azdel, especially the door with constant opening and closing and vibration will hold up. I drilled a hole in mine(not door, BUT same idea) to run a wire, drill went though both layers and that foam like it was hot butter, very little resistance. There is simply very little for a screw to bite into, the foam will hold nothing and you have maybe 2-3 threads on a course threaded screw clinging to that Azdel for dear life.0
- 957 Air Conditioning & Refrigeration
- 922 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
