Connecting suitcase/portable solar to battery
Michael49
Member Posts: 140
Just bought a 100W suitcase solar with built in controller to use on our 400 (to supplement the rooftop solar when the roof is in the shade).
It comes with alligator clips to attach to the battery but the battery in the 400 is difficult to access.
I was considering attaching some heavy gauge wire (8 or 10 gauge) to the battery (maybe 2 feet long) which I can use to more easily attach the alligator clips to the battery. ? Wire lugs on the end of these wires to attach the alligator clips to (covered when not in use).
Any better ideas/options?
Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.
I installed a Zamp Solar port on the side of the front cubby, like on the 320, and ran wires to the positive and negative terminals in the junction box right below it. I attached it to the same lugs that the tow vehicle charging wires attach to.
Rich2019 T@b 400
Installed a Furrion Solar port for my 100 w portable
2013 Tundra TRD 5.7L
Massachusetts0 -
Looks great Denis - I might do this eventually but trying to keep it simple for now. Did you do the install yourself?DenisP said:Installed a Furrion Solar port for my 100 w portable
FYI - I'm in Western Mass.Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.0 -
Thanks - Any photos?Horigan said:I installed a Zamp Solar port on the side of the front cubby, like on the 320, and ran wires to the positive and negative terminals in the junction box right below it. I attached it to the same lugs that the tow vehicle charging wires attach to.Former T@B 400 owner, now thinking about a 320. 2019 Honda Ridgeline.0 -
This guy did it on his 400. He has examples of the SAE port he used. From Big Guy Tiny Trailer:The 'dreaded" Zamp plug is simply an SAE connector. That style connector has been used for a while on battery tenders, etc. There are many simple harnesses that would attach to the battery and allow an SAE cable from your controller to click right in. Honestly, I don't really know where the access to the batteries in the 400 is, so this may not be as easy as I'm assuming.
Towed by 2014 Touareg TDi1 -
Here's a picture of where I installed the plug on a different trailer. Easier to install here on the 400 compared to the side wall near the battery. The junction box is below this on the front frame.Here's a link to the Zamp port that I used.
Rich2019 T@b 400
A 7-pin socket wired to the Ground and +12v terminals lets you use your trailer pig tail as an access port to the battery.Shown here with a SAE type plug installed
2 -
this is the same thing I did yesterday works finerfuss928 said:A 7-pin socket wired to the Ground and +12v terminals lets you use your trailer pig tail as an access port to the battery.Shown here with a SAE type plug installed
2020 tab 400 BDL & 2013 siver shadow 5x101 -
I wouldn't use the alligator clamps anywhere other than the battery terminals themselves.A simple option would be make your harness with ring terminals on one end and MC4 connectors on the other. If you replace the suitcase's alligator clamps with a couple more MC4s, you'll have a sturdy plug system for attaching your panels. Attaching the ring terminals and MC4s does require making crimp fittings (but so do most other solutions).I use a modular controller and did something similar with my battery. In your case the controller is probably on the suitcase so you would only need two connectors.
2015 Nissan Frontier SV V6 4x40
