Loud water pump
Is it normal for the water pump to sound like a jack hammer?
    Normal is relative, but he short answer is yes.
  • BaylissBayliss Member Posts: 1,477
    @webers3, if you add some water pipe insulation foam around the shower water pipes (behind the panel to the left of your television), you can reduce a lot of the "jack-hammer" noise.  The padding prevents the pipes from banging against the wall when the water pump is operating.
  • Jackie_DaveJackie_Dave Member Posts: 73
    Ours was sounding like that. We cleaned out the filter attached to the left side of the pump. There was some debris in it. Can't hardly hear it at all now.
    2018 T@B 320-S / 2007 Toyota Tundra
    Harpers Ferry, WV
    If there is rigid piping in/out of the pump, you can also install some flexible hose on both sides of the pump, and some rubber isolation washers (if not already present) to help quiet the pump.
