Mod on fridge
@Dalehelman.  I saw somewhere you did a mod putting a decorative metal panel in the side panel on your fridge for more airflow to the fridge.  Questions:
1.  Do you think you will get cold air coming into the interior during cold temps?
2.  Did you consider just drilling some holes in the plastic cover rather than the decorative metal?  I'm not sure I could get perfectly straight line cuts in the cover.  What did you use to attach the metal to the inside of the plastic cover?
3.  I took off the cover to look at that area-- mine has a piece of reflectix on the inside of the plastic cover-- what would that be for?
Thanks!
2018 Tab 400
