duckblind123
Member Posts: 65
Let me start by saying that I am not an A/C expert and know
just enough to keep mine going. With
that as background, I’ve been reviewing many of the posts on this forum and
wanted to post an item for discussion.
The A/C currently installed in my 2016 T@B Max S (now called the T@B 320)
is a Danby 5,000 BTU Window A/C. The window A/C
has exhaust vents on the side of the A/C and are funneled to the rear of the A/C unit. The unit is totally enclosed inside the T@B
in a built-in box. Many have commented
on the fact that the A/C unit is venting inside the T@B A/C box and that air is
being funneled outside. I have read
posts of some modifications members have installed to separate the exhaust air
from the intake air to try and keep the air cooler on the intake, thus
increasing the efficiency of the A/C unit.
My question for discussion is since the A/C unit is basically
sitting/installed inside of the T@B, would a wall A/C unit be better suited for this application versus
the window A/C unit. I realize that the
wall units are usually more permanent and more expensive but can be more
efficient. I am just curious on
what would be the differences in the window A/C vs. the wall A/C installed
inside the T@B.
2016 T@B S Max (H@banero) - 2025 GMC Canyon Denali - Magnolia, TX
