That Little Metal Tab
RZRBUGRZRBUG Member Posts: 890
Does anyone know the purpose of that little metal tab that comes attached to the tow chains?  Mine came off sometime during the first trip, so I can't go take a look at it.  I "think" the information stamped on it contains things like towing capacity, or maybe chain capacity.  I was wondering, if that is the case, whether having this information attached to the chains is a requirement.  Any one know?
BTW, I have since installed heavier chains and separated the attach point so they can be crossed when towing.
Happy Trails Y'all
States Visited Map
    I took mine off. I recall it had the mfg info and perhaps load limits. It was held on by rusty wire so I can't imagine that it is a requirement.
    I didn't have one on either my Little Guy 4-wide teardrop or my Silver Shadow.
    Yes, flimsy, rusty metal wire as I recall.  Some chains and connectors now have their load capacity stamped on them.  Not something I'm concerned about, but just curious.  Well, I'm concerned about the load capacity, of course, but not whether the information is tagged...unless it turns out to be a requirement.
    Happy Trails Y'all
    States Visited Map
  • RollingLagrimaRollingLagrima Member Posts: 435
    Larry, I still have mine attached. I will reply tomorrow with a photo if somebody else does not beat me to it. Woof to Booger too!
    Thanks, Sally.  Woof back to the hounds.
    Happy Trails Y'all
    States Visited Map
    Never saw one of those on mine - dealer must have removed it.
    Mine came off so I keep it in the cupboard in the T@b.
    It's just like the tag on your mattress. =)
    The manufacturer is required to attach the tag declaring that the chain is certified to a particular weight limit. Once you have confirmed that the dealer has not supplied a bicycle lock chain, there is no need to keep it.
    Mattress tags <- You mean you can remove them?
    edited May 2015
    I think I threw it out.  I'll be interested to see the picture for the specs, in case I replace the chains.
    I should have added a smiley :-)
    I do remember people taking those tags seriously and we'd play along as to how it was a weekend in jail if you ripped them off.
    I have all those tags saved in my drawer, in case 'they come for me' - I can glue them all back on quick.
    But the new mattress tags have an electronic sensor that reports directly to the NSA....
    Those new mattress tags also report if you're sleeping around.
    That's why I hide them in the drawer, so they can't see if I'm sleeping at home or not.
    edited May 2015
    So glad I was able to provide a platform for some comedic relief. =)
    Happy Trails Y'all
    States Visited Map
    I think that per OSHA regulations any chain that is used for LIFTING, MUST have a tag on it that states the weight capacity of the chain. Not sure about safety chains on trailers, but they must have been put there for a reason.
    I believe you are right.  Any sling (whether made of chain, straps, cables, etc.) used for lifting in a commercial setting must be labeled per OSHA regulations.  They are not going to come inspect a hoist I might have hung over a tree limb or from the roof of my garage, unless I'm being paid by someone to use it on their behalf.
    Also, the Federal Department of Transportation/Federal Highway Administration requires chains and other tie downs used on commercial carriers must be tagged (or stamped).  They are not likely to check the strap I use to tie down the lawnmower in the back of my pickup (unless they spot an obvious hazard in passing).
    These things I found in my research.  I still didn't find anything pertaining to tow chains used on a travel trailer.  I think this would indicate that there are no requirements after the unit leaves the manufacturer.
    As I said before, I'm not really concerned about this other than knowing that my chains (and hopefully, yours) are adequate in case of a breakaway.  It was just something I thought of and curious minds want to know.
    Happy Trails Y'all
    States Visited Map
    I still have mine. I will post a photo for reference, when I get a chance.
    I spoke to the factory about this last year and as noted it comes from the manufacturer and can be removed without incident.   But heard that yours was found out on I-80 somewhere near North Platte, Nebraska and that the Department of Homeland Security has a warrant out for your arrest.  Evidently Booger was observed lifting his leg on it at a rest stop, the tag rusted off and fell to the highway, punctured the tire of a semi hauling a load of chickens to a Tyson factory in Waterloo, Iowa....  Well, you know the rest of the story!  smilie    smilie
    Uh oh.
    Those would be happy, 'free range' chickens now, and we all know what the DHS thinks of liberal chickens!
    (Did I just bring politics into the forum again?)
    LOL, Mike.  Gives a whole new meaning to road kill dinners.  I bet his tie-down straps/chains did not have that little metal tab either.
    Happy Trails Y'all
    States Visited Map
    Seeing those chickens brought back a childhood memory - We had a small chicken processing plant in town and on the days the trucks rolled in, a few would escape. The plant paid a nickel for every chicken you could catch. A wire hanger with a little loop at the end worked best.
    Of course we always went home broke because the Pepsi bottling plant was right across the street and pop was a nickel.
    After reading this post today I took mine off, and yes,the wires were rusty, and we don't even have a dog. ( MUST have been Booger) So anyway, the tag states that the chains are good up to a 3500lb.(each) jolt. Should be good.    Thanks for all the info Mike!
    Thanks JandJ.
    Oh, and BTW, I really was on I-80 near North Pratt, Nebraska last June on my way back from Yellowstone/Grand Tetons.  And come to think of it, seems like that may have been about the time I lost those little metal tabs.  Guess I'll need to detour around that spot next time I'm out that way.
    Happy Trails Y'all
    States Visited Map
  • RadRad Member Posts: 516
    I have seen enough chickens in my day, I grew up on an egg ranch
    So Rad, do you still eat eggs?
    Ok Larry, so tomorrow turned into a week later. Better late than never I say! Here is the photo of my chain tag (Silver Shadow).  As you can see, mine is hanging precariously by one tether point. Bring on the nightmares of incarceration for little metal tag loss... :-0
    LOL.  I had already forgotten about it.  Thanks.
    Happy Trails Y'all
    States Visited Map
