I have looked into a portable small tank fill system for filling and or topping off the factory nitrogen filled tires. About the best I've found between the tank, the gauges, hose, valve and gas combined is $300.00 or more. Is there a cheaper version out there. I know I could go to a tire place, but up in the mountains where I go, there aren't too many tire places. Does a 1700lb. single axle trailer really need nitrogen filled tires? Yea, I know they last longer, maintain their pressure longer but really?
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado
1 ·
2014 T@B CS Maxx
Martha Lake, WA
Good choice.
Sterling, VA
So how many owners actually care and have maintained nitrogen in their tires or just swapped over to air?
Odessa, Fl.
And unlike you said and some other have mentionned up-here, if filled with the right pressure, and speed rating and load is respected, a tire will not overheat., so internal pressure should not be much higher after getting off the road.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
