I have been researching the best option to have my roof fan open all the time.
Option 1. Replace fan assembly with Maxx air fan and cover, or a similar unit.
Option 2. Fit a lowering or permanent vent cover to allow fantastic fan to be open in rain.
Option 1. Researching the popular Maxx air assembly.- easy to fit but poor service from manufacturer, no warranty with Amazon and control module prone to failure if there is a lot of condensation. Maybe some protective spray coating for the control board?
Option 2. None of the permanent covers last longer than a year or maybe two. The material gets brittle and falls apart.
Anyone got any other good options?
I had an Aero Flo vent cover on my Silver Shadow teardrop for two years before I upgraded to the T@B S Max. It was in my garage a lot when not traveling,
I had the factory install an Aero Flo vent cover on my T@B 400 with the 13 speed Fantastic Fan and it has done well for the past 15 months. It still looks good, still doing its job of me being able to vent with A/C or with heat in any weather. My 400 has been outside since the day I brought her home.
2013 Tundra TRD 5.7L
Massachusetts
There are no holes drilled into the roof, and no need for any sealant.
@Tundra57 I have no knowledge of the Fantadtic Fan Cover. I like the sleek look of the Aero Flo vent cover.
Madison, Wi
and can be done in a couple hours. I'll will need to type up the short cuts and tricks I used.
Hamburg, NY
2021 T@b 400 Boondock
2020 Kia Telluride AWD/
Hattiesburg, MS
